the truck was a repo truck for 250k miles. averaged 100k miles per year. driver was hauling a car one day when it started knocking and he pulled over. they towed the truck to a shop where they diagnosed it as a lower end knock. i bought the truck as-is for cheap thinking it was a bad injector. i had no idea these motors were common to break cranks at that time. lol
anyways, it never had a tune or any mods, supposedly and looking at the cylinders/pistons i would tend to believe it. all the bearings came out of the motor looking real good other than the #1 bearings, and that is where the broken crank was see-sawing on it. all the rotating assembly looks great, doesnt even have much of a black stain to anything at all. oil changes were done regularly.
i will see if i can check the block in the way you suggested, thanks for the headsup. i used a bore dial gauge on each of the bores with the caps bolted in place and they all looked nice and round/comparable with one another. the #2 main actually measures decent top to bottom, but when you rotate the gauge around towards the seperation line, it gets tight. you can run your finger across the line and it catches on the main cap on each side. its like the cap was removed, put in a press, and squeezed in .011". which gives .006 on each side of that bore to catch your fingernail on.
