Alright guys, I have two trucks. An 01 LB7 with a built motor and compounds and an 09 LMM with triples and built trans. The body of the LB7 truck is rough and there is some rust on the under-side.
My LMM with triples finally let out the ghost.
How much of a headache would i be in for if I wanted to put the LB7 and its built trans into the LMM?
Next question... could I put a set of LMM heads on the LB7 short block and use LMM injectors and the LMM wiring harness and avoid having to do the ECU swap?
I already have a stock LMM that I'm putting head-studs in while its out of the truck and I got the idea to put the fun engine in the nice truck.
More trouble than its worth?
Thanks
-Jared
Thanks
-Jared
