LB7: Lb7 injector hard line
ACiFiC
Oct 14, 2012
119
Canada
Just started doing my injectors and I'm at the injector lines with 19mm nut thingy.
They are tight as hell... But anyways it's starting to round...
Wondering if I should just cut the line and try to get a socket on it?
Or any ideas?
Duramax One
Vote for Pedro
Aug 11, 2012
140
Oroville, CA
I personally recommend tracking down your local Snap-on dealer and snagging either the 6-point (FRHM19) or 12-point (ANM19) crowfoot flare nut wrench. If the nuts are already rounded you may have to get more creative, but the crowfoot should keep it from happening to the rest.
You can also get the Snap-on flare nut socket (FRXM19), but I believe it is only available in 6-point, so it may not fit if you've rounded the nut significantly. Also, I believe the FRXM19 is spendy, even by Snap-on standards (you can get both crowfoot wrenches for the price of one socket).
Worst case, you can cut the tube and use a standard socket or the boxed end of a 19mm wrench. You're going to be replacing the lines anyway, right? :thumb:
PACougar
2,105
41
El Dorado Hills, Ca
Follow this advice, those sockets are freaking awesome!
