Lb7 idle surge in park
Oct 11, 2024
5
3
Dover pa
Hello, I have a 02 lb7 that only surges in park, not in drive but only in park and started smoking a good bit. Decently has a strong fuel smell. I replaced my fpr and that did not fix my problem. I have a ct3 so I checked my injector balance rates and the worst one was sitting around 1.2-1.3. I’m lost, anybody have any ideas?? Thanks.
Oct 11, 2024
5
3
Dover pa
1,835
Merged your threads and moved them into LB7 section.
Did you use an OEM GM FPR? You'll have to find out what your main fuel rate is in order to accurately see how the injectors are doing.
Bdsankey
4,152
1,262
Larsen, Wisconsin
From the Dmaxstore
They're reputable so that isn't a concern. Thanks for the quick reply!
Do you have any way to data log the truck?
Also, as recommended above by another user, checking return rates and balance rates is a great start. With balance rates you'll want to check main fuel rate as well.
