I have an LB7 that is not turning the glow plugs on I can check with a meter when I turn the key on and no voltage is being sent to the glowplugs I have power to the lug on the top but doesn't seem to be activating the relay to send power to them. it is a Cali emission LB7 also. does the relay get its ground through the mounting hole that has metal in it? and what are the four wires in the center plug doing? I have voltage on 3 of them and a ground on one. if anyone has a wring diagram for this that would be great also I have deleted the AIH and its relay.
