LB7: Lb7 fuel leak
gmasko
73
Sacramento
I am by no standards a mechanic and after much hesitation and reading and researching I decided to save money and do injectors myself. This was about 128k miles and now have 130,500.
Sent from my XT1060 using Tapatalk
gmasko
73
Sacramento
gmasko
73
Sacramento
It's leaking where the h/p lines connect to the injector and its spilling out on the valve cover. What could I have done wrong here to cause it to leak so I can do it right. Yes I am making oil also.
RPierson51
racer
Jan 5, 2013
17
budd lake,nj
Did you replace the HP pipes when you did the injectors? If not the old ones need to be really cleaned well if there being reused, if any debris got in there at all they will leak, gotta be torqued to 30 ft.lbs also
gmasko
73
Sacramento
No I didn't replace them, which made me nervous cause I was warned about it. I did soak them in carb cleaner, and then thoroughly rinse them out as I read somewhere on here. I guess trying to do it the cheap way just didn't work out for ha-ha.
