Lb7 engine build
bryceLB7
Oct 26, 2014
15
plus.google.com
Ok guys I'm in the process of buying an epr twin kit with an s475 over stock and getting a great deal on it. Im wanting to do head studs, head gaskets, injectors, and maybe rods. I'm wanting around 650 horse and everyone keeps telling me to just do Carillo rods and get it over with. But if I don't have to I don't want to. Just curious if there's anything you guys suggest doing while I have the motor out? Not wanting to spend a whole ton of money on it
2004 Lb7 --
Fass 150, ATR transmission, 3 1/2 straight pipe to 8 inch tip, edge insight CTS, boost increase valve, EFI live by Blake Crenshaw, 20x10 fuel throttle on 305/50 nitto 420s, 212,000 miles
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Carillo rods a must IMO. I know you're sick of hearing it but everyone is telling you the same thing for a reason. They have proven themselves over and over again. Never a better time to put them in. If I had to do my build over again I would have done an Alternate Fire cam, Fingers cast oval pistons, upgraded pushrods, and a new Oil cooler.
Main studs, new oil pump, Clevite bearings, upgraded valve springs, and new CP3 in the valley is also a good thing to do while the engine is out. I'm sure I missed a few things
It's really the same conversation as the built trans questions that pop up all the time. The answer is still the same... Pay a little more ya but DO IT RIGHT THE FIRST TIME and save money in the long run. Skimp on certain things and you very well may end up doing it all over again
Yngdmax92
962
throw on the twin kit and just run it for a while and save up money to do it right. If your tuner knows what he's doing your motor should live a little while atleast
bryceLB7
Oct 26, 2014
15
plus.google.com
Good point, what would you say if I told you my head gaskets are leaking?
2004 Lb7 --
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
When you crack those fuel lines your going to fill them sticks with rust and dirt,clean them really well or maybe a set of remands might save you some grief.
bryceLB7
Oct 26, 2014
15
plus.google.com
Sounds like I might be buying a few more parts..
2004 Lb7 --
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
2004 Lb7 --
I'd tell you it sounds like a problem..
bryceLB7
Oct 26, 2014
15
plus.google.com
Wanting to put new sticks in there if the budget allows it, thanks for the tip though
2004 Lb7 --
SilveradoTwins02
Hopefully twins soon
Aug 5, 2014
194
Hanover PA
You could look over at my LB7 7 build thread to see some pics of the mods that should be done on the internals for reliability. found these tips by doing some searching on here.
ctrump90
ctrump90
Jan 11, 2012
471
Clare, IL
Anyone looking for a brand new built long block? Mine will be done here shortly and it looks like I'm not going to be able to enjoy it. Have to move and change careers. Can't afford to keep it... I would make someone a hell of a deal.
bryceLB7
Oct 26, 2014
15
plus.google.com
Message me details
2004 Lb7 --
