LB7 EFILive 106 code
BIGTERRY75
BIG T
Jul 15, 2014
35
ROCKWALL TX
Customer brings in an 01 with EFI live and DSP5.
Has the p0106 code in ECM the code will clear but comes back on second key cycle.
He replaced both sensors (map and baro)
Wiring is good from sensors to ECM
Customer does not have the autocal box to return to stock to check if it is the tuning.
I am not a tuner.
While monitoring each PID on a scan tool neither of their values ever change. That was looked at while driving and with a vacuum pump on both. Port to intake is clear.
QUESTIONING the tune right now. Should I be?
Or should I just send the ECM out to be repaired?
Hope you guys can help.
Thanks In advance
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Do you have another ECM to try? I think you should be able to plug one in and once you get through security it'll act as it should.
Or flash it back to stock and go from there?
BIGTERRY75
BIG T
Jul 15, 2014
35
ROCKWALL TX
No sir no spare.
Customer doesn't want to lose the tuning.
He is trying to contact Cory to see what his options are before we reflash.
Other than that we are just going to send it out to see if the ECM is just bad.
