lb7 downpipe
thedirtyD
Dec 14, 2014
port Hueneme ca
just wanted to give my experience with and aftermarket downpipes for my lb7 , so I read on other threads and other forums how big of a pain in the arse it is I thought I would give it a shot so I soaked the bolts and nut with PB blaster for a couple days just occasionally walk out and spray the bolts even drove back and forth to work after spraying and I think the key that made it so easy was buying a flex head ratchet the bolts and nuts came right off with a little muscle and then the hard part was getting the downpipes out which was a pain but all in all took me 3 hrs to do the whole job.
c01t
Dec 6, 2016
15
Did you end up taking the fender out? Was there anything else you can think of that you did to help?
Sent from my SM-S765C using Tapatalk
thedirtyD
Dec 14, 2014
port Hueneme ca
I did take the wheel well out , I soaked the bolts with pb blaster for like 4 days straight over night getting it out and putting the new one in was the hardest
