LB7 crank
tracygto
Apr 18, 2014
90
deshler ohio
will a LB7 crank work in a LMM motor with these pistons??????
picture.php
:confused:
Andrew
Costly Obsessions
Aug 7, 2013
275
delaware
Yes it will work but you need a lb7 balancer if I'm not mistaken. Everything will need to be re balanced as well
tracygto
Apr 18, 2014
90
deshler ohio
damn so wouldn't it be better just to use a lmm crank???? I have a engine at the machine shop with a LMM block bad LMM crank good LB7 crank that was given to me by junk yard that sold me motor so i need to positively know if the LB7 crank will work???
bonomax
223
Hermitage, PA
LMM/LBZ crank is heavier/thicker/stronger than LB7/LLY crank. LB7/LLY crank will work if balanced correctly. AS in internally balance crank by machining the crank self which can be pretty pricey or I think you could just use LB7/LLY balancer and flywheel again lil pricey. IMHO not worth trouble or money just get a good LBZ/LMM crank.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Never heard this before.... It must not matter because they break just as much as the others. Pretty sure last I checked the broken crank thread, all models were neck and neck.
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
:hug:
I think your getting that mixed up with LB7/LLY pistons. stock LB7/LLY pistons were made by mahle and less prone to cracking in higher hp setups like 700hp plus than LBZ/LMM pistons
No I'm not getting it mixed up lol. Pretty sure Kyle harbin for example just put a new lb7 crank in his lmm.
bonomax
223
Hermitage, PA
dont know kyle harbin but The part where the cranks break at the journals as in where the rods ride on are the same size lb7/lly to lbz/lmm. So thats prolly why the cranks breaking is pretty even. I guess maybe they go with LB7 crank since its lighter so to make more power with less rotating mass.
I wasnt saying one more prone to break just that their different mass so need balanced differently just to answer the OP question. Just think be easier and cheaper for him just get lbz/lmm crank. depends tho on how much hes building the motor like if getting internally balance already then go with lb7 crank he has already.
bonomax
223
Hermitage, PA
sorry i didnt mean to mislead that one crank is less prone to break than other by saying stronger. I just answering the OP questions and explaining the physical difference.
durallymax
Apr 26, 2008
2,756
Under The Hood
Don't hear it often but if you do the LB7 crank seems to be preferred for whatever reason, along with the LBZ block and LB7/LLY pistons with LBZ rods. If you are looking to mix and match stock parts.
Harbin_22
3,858
Southern Indiana
:hug:
My LMM truck had an LLY block with a new LB7 crank with carrilos and SoCal pistons. Had the appropriate balancer and flywheel for lb7. We are putting an LBZ crank back on it this time.
Harbin_22
3,858
Southern Indiana
The lb7 only lasted 4,000 and a handful of times over 900hp. Could have been a fluke but said the hell with it and got a used crank from a buddy.
