Question: LB7 cp3 problems
sddmax
<---- Gone Forever...
Feb 9, 2010
224
35
Garretson, South Dakota
I have a stock motor truck that needs a FPR ( it has had the lopy idle syndrome for awhile now) and i noticed shortly before the lope started rail pressure started dropping off at wot. I am wondering if the fpr can cause my low rail pressure? or did something go wrong and im gonna need a new cp3? I am only seeing 15k psi at wot :mad:
Gya0ma7ha
From driving the truck
May 6, 2009
19
I have the same issue, can't hold rail pressure at stock ipw. I bought a used cp3 off of a wreked truck, hoping this solves the problem. I have no top end power, how about you?
sddmax
Feb 9, 2010
224
35
Truck loses power on top end bad... i have another cp3 sittin here as well, just need to find out if i can fix the problem with out replacing the whole thing.
sddmax
Feb 9, 2010
224
35
ok finally got a chance to unplug the FPR and i got 25k out of the pump... so pump is good just need a good place to get a modded regulator. Any suggestions? I'm leanin towards wicked diesel....
