Lb7 cam reluctor on lbz cam gear?
6,025
Does anyone know if the timing marks between the lbz and lb7 are any different from each other? I know the bolt holes are wider on the lbz cam gear.
Long story short, found my lb7 cam gear missing two teeth but have a lbz cam gear here with no reluctor. I’ve machined the bolt holes to accept putting the lbz reluctor on. Just not sure if the air gap or timing is different
Anyone done this?
Machines holes
And broke shit for your viewing pleasure
6,025
so just to close this, there are no issues running a lb7/lly reluctor on a lbz/lmm cam gear as long as it self centers on the locating pins. truck runs great with no ill affects.
