LB7 Boost Help, EFI
paytonlb7
Owner at Torq Industries
Jul 16, 2010
54
Idaho
www.torq-industries.com
Truck in signature,
I can not make more than 25psi boost at WOT. Correct me if im wrong but I can not adjust boost in EFI, I can only set the limit with my IMI wastegate turbo, So I have my boost table maxed at 37psi and I installed a PPE boost increase valve and still can't get over 25psi. I have plenty of fuel, more than a light haze at WOT. So I found on some forums where guys had plugged the wastegate hose and payed close attention to my boost gauge when running it. But still the same thing. I am wanting to hit 30psi max and clean up that fuel. Is there anything else I can do? Changes in fuel or timing tables??
Any help is appreciated! Thanks
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
There is no way to adjust boost on an LB7 with EFILive. Your boost will be determined by fueling, RPM, and wastegate adjustment.....Sounds like you need a bigger tune.
feltersnatch
Mar 25, 2010
45
IDAHO
If I remember right the tune he is running is bigger. Fuel shouldn't be a problem. How is the wastegate adjusted.Turn Clockwise for a higher threshold?
A boost leak is a possibility.
feltersnatch
Mar 25, 2010
45
IDAHO
Thanks for the info man!:thumb: Ill try to keep him away from the juice grips, unless he wants a to buy a charger in the near future. :spit: Iv only heard negative things come from the juice grips. Is there something I'm missing here?
Righteyeblind
712
Fairbanks, AK
put a needle valve in line and crank it down till you get the boost you want. If you have enough fuel in your tune you should have no problem getting 30 psi
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
The stock actuator is not strong enough to hold over 25-27 PSIG of boost pressure, weather the signal line is hooked up or not. You can do some modifying and get the stock actuator to be adjustable like the banks unit, just takes a little time and knowledge. However, the stock turbo is already outside its map at 25 PSIG, let alone 30, so you will actually not gain anything but heat. Sure, you will have more pressure, but the temperature of the compressor discharge will skyrocket, thereby making the increase in flow a moot point. My suggestion would be to leave the turbo alone, rather than make it work harder for very negligeable gains, and chance a compressor or turbine wheel failurre. JMHO.
