I have been struggling trying to get my truck running right I have a 64 mm billet ihi that won't clean up the smoke at wot. My truck gets high egts pulling a 20' bass boat i have boost tested the truck found a small pin hole in the intercooler and a hole in driver side intercooler pipe but with no big gains. My boost is right around 29psi and with my turbo I should be in the upper 38-39 area I live at 5500 ft in emigration could this be my problem I have also changed the manifold and up pipe gaskets no leaks there. Any suggestions thanks also I have trucks in same area with stock turbos that will walk away from me in a race on the upper end
