Just wondering how large of a injector I can flow with a single 12MM pump. Have 250's from S&S and have a spare stock LBZ pump or a 10MM also, just wondering how much fuel I need pump side.
Thanks.
Thanks.
Thanks.
Kinda what I wondered. I was really hoping to stay conservative at 1k. That would be the most I can see myself making.
Interesting cause I am moving up to 150 overs and looking at a 12mm cp3 on my 2011 built Co Cal Stage 2 LML with twins. Currently running 45 overs on a 10 MM CP3. I was considering the 14MM but now think I will go with the 12MM.
A race 14mm is awesome. Mark at Danville is holding 2200US on his race 14mm with LBZ 250% overs in his white truck. The street pump has a different gerotor section and some other small internal tweaks according to Exergy.
If you already have the 10mm just add a stocker over it and be done. That is tons of fuel. I went with the street pump because I did some horse trading with another member on here.
OK, I am going to look into that, thanks. With my setup I know I can move up and just wanted some opinions on which way would be better for a street truck. Currently sitting at 830 RWHP.
That being said, I know if you can wait on fuel until Thanksgiving LDS/S&S usually have a damn good sale on 10mm pumps, to the point where you can snag one for ~$1450-$1500.
There is a lot more to maintaining rail pressure then just the pump.
Gotcha. If you need any parts let me know, I can see what I can do in terms of pricing on a pump to help you out.
Don't know if I'm allowed to post that or not, waiting for a mod to say something if I can't.
I realize you're trying to help (you also mentioned GM parts in another post), but don't. Your only warning.
Sorry I have to be the jerk, guys.
Feel free to fill me in. Truck has a Fass 260HD on it so I do not think supply will be a issue to the pumps.
a 14mm should be able to supply more than 1750uS IMO.....
We run 250s in our 2.5 truck with danville tuning and with a 12mm we can hold 2200uS just fine. You might want to check inj return rates.
Im running 2 stock LBZ pumps with 250s and they hold rail at 22-2400uS, I don't remember what Mark set it at exactly.
Street pump or race pump?
Like I said, my pump only falls off after 3500rpm. After talking to Mark @ Danville and Bob @ Duramax tuner they believe that is where they think it could be due to the restrictions above that rpm.
I'll do a return rate test.
It’s a 12mm pimp. There’s no race or street version. But we turn 42-4300rpm for what it’s worth and hold 29k
