L5P Tranny lines rubbing on bumper brackets
1,868
If you dont lower the front of the truck, it'll still happen with the new set. So solve the real problem....
5,833
maybe its cause ive not really looked at one but i cant see how a cranked front end is causing this. Lift kit maybe due in part to how the crossmembers are installed and trans lines are ran but cranking the front shouldnt change it unless im missing something????
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Mine was rubbing when I reinstalled the front end.
Easy fix with a cut off wheel while there is no bumper
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
It’s actually a common issue on the L5P. Almost every truck we have had in has had some rubbing right there, some are pretty bad for as little mileage as they have. My personal truck was rubbing through also.
