Hey guys, I'm Currently installing a 30" Rigid SR-2 behind my grill and everything is good to go, I just want to make sure this is right because I'm coming from the side post LBZ batteries:
Where do you guys attach your power wire eye on the driver side battery?
Is there a spot you prefer for grounding the light rather than the negative terminal?
I'll attach a picture of the positive terminal without the plastic and if someone could identify where they believe the most solid connection would be that would be much appreciated!
For reference sake I took a picture with a few places I was looking at, like under the T bolt, and then the other two nut locations.
I'd like to thank in advance anyone that has any suggestions, it's very much appreciated.
