Wondering if any of you l5p gurus have some failure analysis input for me.So this truck came to me with a miss on one cylinder and a pop out of the intake,pulled the valve cover and found the valve lash extremely loose across the board,so loose one of the valve bridges had come out.Tore the heads off and pulled the lifters out and this is what I found along with the other lifters which all have loose follower bearings.Truck has 158k,towed its whole life,and was serviced with amsoil every 5 to 7k miles..Any thoughts on what could have caused this?I have found there is not a lot of info online on l5p internals.Gale Banks of course but in his book the l5p is perfect so nothing much goes wrong....
Sent from my SM-G981U using Tapatalk
