Does anyone know if the l5p Denso 220amp alternator will fit a lbz and if the pulleys match the belt off the top of their head?
I'm still running the stock fuseable link from my LB7 alternator with an aftermarket 300 amp alternator LOL One day it'll pop and I'll put some real cable on. But since the ECU controls the field to regulate voltage as measured by the ECU, any losses in the undersized cable are compensated for :spit:
I've been considering an upgraded alternator for my Suburban. Think the Desno 220 will work on a LB7? It has the stock 140 amp, but with the quadrasteer I'd feel better with a bit more power available. I don't know if the LB7 and LBZ alternators are compatible.
Hmm, I think you're right. Thinking about it more, on cold starts, the voltage comes up to 13 right away, then jumps up to 14 once the glow plugs are off. I bet that's the voltage drop across the fuseable link I'm seeing.
Maybe I'll put a new one on sooner than later.
I wouldn't see why it wouldn't work with an LB7, I have mine wired to the brown wire on the main alternator. Fairly certain the LB7 ECM controls the alternator so it's just a matter of splicing it in.
ECM alternator control where it controlled the charging voltage didn't start on the duramax until the LMM(didn't start until 04/05 on 1500's). They kept the 4 pin plug through at least the LBZ. The ECM simply turned on a keyed on power to field it, and monitored the charge circuit. If you run a 2 wire plug alternator on a different vehicle, you only get 13.8 volts default voltage output.
I know for a fact my lb7 uses an old style alternator and is wired like factory where the ECM fields it. I know somebody else who wired in an older cs144 to his LB7 using the factory wiring to trigger it. Its easy enough to get a 200 or even 300 amp ad244 if one wants it.
I have a 300A modded AD244 on my GMC. I was thinking the L5P alternator might be cheaper than a modded AD244, hence my interest. A high quality AD244 in the 200+ amp range is $300+, and it looks like the L5P 220 amp is $250-ish.
