knocking sound when running, still can't find the problem
Teamvi
Oct 26, 2011
333
Well i pulled more off and leak down test seemed fine but when I roll the motor over with the starter it's like it pips threw the intake, I took a video and will try to post
Teamvi
Oct 26, 2011
333
mine will do it when you crank it over with the starter, what was the cause of your maxed out fuel pressure?
Teamvi
Oct 26, 2011
333
cranked it over with a push button on the starter, pulled ignition fuse 1 and 2 and fuel pump fuse, also have passenger injector lines off and passenger valve cover. so I don't think its fuel pressure
Huffy67
Dec 26, 2014
270
Arkansas
I would say you are right
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
If pump fuse is pulled it will max rail out so you wont find the prob that way.Check voltage at fpr plug.Possible a rocker bridge is knocked off?checked valve adjustment?Check your rail with efi.
Huffy67
Dec 26, 2014
270
Arkansas
He is not starting the engine so there is no way it is maxing rail pressure. He is only turning it over with the starter and hearing the popping noise. It is more than likely a valvetrain problem.
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
I was getting the same pop from my hood stack while cranking and thought for sure I f ed up valves,timing,ect,ect but ended up being a max rail pressure prob.Op,Do you have a way to check?It very well could be a valve train prob but should eliminate the easy stuff first.
Teamvi
Oct 26, 2011
333
Mine is poping threw the intake not the exhaust and my fuel lines aren't even hooked up right now cause im pulling the valve covers off to check them out, is there anyway to roll the motor over with out the starter? also have most of the glowplugs out
