LB7: Kill switch to stop thieves
MidnightLB7
Feb 18, 2018
23
The thieves are starting to steal 1999-2007c GMC/Chevy trucks in my town and I don’t want my trucks to go missing, just wondering which wire or wires are the best to install kill switches in that will be most effective or other anti theft ideas out there
Thank you
Apologies in advance if it’s the wrong sub forum
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,692
388
P.N.W
If you have efi live you can always have a valet tune written. I had Rob at ATP write me one when I was running his tunes in my truck.
MidnightLB7
Feb 18, 2018
23
I don’t have EFI live yet but I plan on getting it, having a “kill switch” in the computer would be slick
subman1980
Feb 4, 2013
23
Google Ravelco. It’s the only way to do if you want to be sure it’s not going anywhere without a tow truck or trailer. Just have to get in the habit of taking out the “key” every time you park it. Installed them on our fleet and haven’t lost one since. $500 or so installed, they come to you. Have them on my personal vehicles also.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Long!!! Before doing this I would buy a V2 and DSP switch and write a valet tune. Very easy
2,137
What I've always pondered was putting a reed switch hidden somewhere convenient and have a little magnet as a key to allow it to start or run. Pull the magnet off and it is now in valet mode, or wont start, etc.
What I don't like about a key is it may be discovered and bypassed pretty easy. And trying to hide it somewhere would make it a nuisance, and possibly not used as often as you should. Then that one time you leave it on is when it would be stolen.
If you do a magnet, you can put it right up front and easily accessible. Could make it similar to the magnetic safety switch you clip on you that is found on the treadmills
3,727
296
You could easily wire a magnetic reed switch to the DSP2 input on a LB7 instead of a regular switch or keyed switch. I would also do the DSP2 setup, especially if you want to get EFILive anyway.
Ben (duratothemax) retrofit PassKey 3 onto his GMT800. That uses a unique coded transponder inside each key, and is much harder to bypass than PassLock 2 that is used on the GMT800 normally. He is almost impossible to get ahold of, so I am going to try and figure out how to retrofit it onto my LB7 this summer. If I get it working, I'll do a writeup. But be warned, I suspect it will not be an easy conversion.
Midnight, for the specific situation you're in, how are the thieves stealing the trucks? Are they getting new keys cut off the VIN by a dishonest locksmith, or are they brute forcing the ignition switch? If they are getting keys made from the VIN, you can find someone else with a GMT800 and swap all your lock cylinders & keys with them. Then your locks won't match your VIN, and a key cut to your VIN won't run your vehicle.
My brother and I keep contemplating this strategy, but I think the PassKey 3 conversion would be even better (couldn't just force the ignition with that), so I am going to try that first.
MidnightLB7
Feb 18, 2018
23
I believe they are just smashing the columns, one of the LBZs they recovered the column was destroyed on it and the people had been living it, not sure if it had an alarm system or not in it but the one stolen most recently did have an alarm system in it
My dad has an LLY so I could swap all the locks and keys with him, I don’t think the thieves are getting keys cut but they could be
I do like the EFI idea with a DSP2 I will contact the closest tuner and ask if he can do that for me
MidnightLB7
Feb 18, 2018
23
Can EFI live be used on the same generation of gas trucks too?
Robby Avery
GM TECH @ FENDER GMC
Jul 31, 2008
820
Norman Park, Georgia
Good idea and where did Ben go no recent posts that I've seen. what company do you suggest for the feed switch not dps thought thanks
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,196
360
At Da Beach
I'd also buy a "Spot Trace" if your that worried about it, that way you can track it if it gets stolen...;)
They aren't expensive, about 100 bucks...
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
There’s a company that makes steel plates that go behind the door handle so thieves can’t just break the handle or push in the lock on the door to open it. I think there’s a thread about it but I forgot the name.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Last I seen on facebook, he was swamped with work doing r&d on bcm stuff for the foreseeable future.
And the whole point of passlock is so if the ignition is forced, the bcm doesnt receive the signal, and it wont give the fuel enable signal to the ecm. One could always install a switch in the dedicated j1850 line from the bcm to the ecm that sends the fuel enable signal. Without that, the ecm will 9nly allow it to run for 3 seconds, and kill it.
torqued2dmax
646
Brookville, PA
Glad you at least found Ben, I hope he will be back with us as soon as he gets some new cool stuff figured out ! Thanks for the suggestion on the j1850 line !
b5widebody
Sep 28, 2023
CA
hi guys, i like the idea of a kill switch into the j1850 line, i am new to this would anyone share more info how to, where is the line etc
i have an lbz and sure would like something like this
thanx in advance
