I am redoing my engine and was wanting to get my cam and crank keyed, but I can't find anyone around Des Moines, Iowa who can do it for me. Is there anyone close by here or around that can do it?
I don't think it is that hard to do, any good machine shop should be able to hook you up
I agree, any machine shop should be able. Most won't have the 5mm end mill and key stock though..
I went to about 5 different machine shop and they all said they wouldn't do it. What do they do, put a bigger key in it or add a another key.
I see what you mean but sill cant see it for $150.00 Most Machine Shops (Not just Auto one) around here charge $80/h. V-Blocks +shims, Dial the part in, cut key, check size, finish pass on cut and de-burr. I a good shop could do that in 15-20mins now do it twice as you want the Cam and Crank. I cant see more than 1 hour work.
Now that I think about it Do you have to Key(broach) the parts the mating part?
If so then $150 is not as bad.
I don't know I may have it all wrong. I am just a Machinist that has been in the trade 12 years.
In a stock crank there is basiclly 5mm pins holding the gears on... a 5mm key way is added but it gets tricky because the crank snout is 2 different diameters the keyway must be stepped so to speak...heres a pic
