Is there anyplace to tie in for keyed power under the hood?
I know a few spots in the cab,but would prefer under the hood if possible
I taped the wires under the fuse panel, IIRC the all pink wires are key on power, one is a heavier gauge than all the others, thats the one i used! i used it to power (engage) a relay under hood so anytime i need key on power i have it readily avaliable from the 40amp relay!
i should of said that i need a fairly nice size gauge wire as this is for powering quite a bit of stuff
I will lift the box up and check for a heavy pink wire
Thanks Yall
