Help: key fob programming
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
Trying to program a remote on an 01 2500HD 6.0,
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder - do not turn ignition switch.
Press and hold the DOOR unlock switch (This is the switch on the door, NOT the remote).
While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF ON, OFF. (3 TIMES)
Release the DOOR unlock switch. The doors will lock and unlock one time to confirm the program mode is actuated.
^ this never happens, any idea what to check??
Simultaneously press and hold the LOCK button and the UNLOCK button on one keyless remote for approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters. Reprogram any existing remotes at this time as they have been erased.
Turn the ignition switch to the ON (one more click forward) position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
Hey Justin any luck with the FOB?
