K&D Service Transmission Lines
Bdsankey
4,187
1,293
Larsen, Wisconsin
I am excited to announce that I've been working with Shocker Fittings to create a transmisison line kit that works for all of my customers. Currently, most options use 90 degree fittings entering the bell housing on the hose with a straight ORB>AN fitting into the trans itself. This works great until you want to add a return cooler flow C3 oiler.
I've worked with Shocker to get a custom SKU for my usage. These kits will feature a 90deg fitting in the bell housing and straight fittings on the trans end of the lines. This allows for easy C3 oiler addition at any time and does not require more than 30min on any truck (01-10 lines currently). This means that once you buy a line kit from us, you do not need to do any drilling or changing fittings etc to run a C3 oiler. We are not the only company doing this, but I wanted my own option that I know will work great and supports a company that's fairly local to me.
These kits are $349 shipped in the continental USA. I will be offering them $75 off when purchased with a transmission going forward.
