I am pegging my 15psi gauge at idle and low RPM on my LB7 and its still going through the FICM. So it could be higher than 15psi easily. IIRC lowest pressure i get was 7-8 psi @ WOT. Love this pump! The FICM did start leaking but i pulled it out and found the case screws were loose, so i tightened them and has been all good! I had heard from some that over 10psi the FICM gets cranky and makes a funny idle. Mine does this but it could be my modded FCA causing this? So ultimatly, one of many small test/projects im wanting to do here soon is a separated FICM cooling system. This way, the FICM dosent heat the fuel more, can run plenty of PSI to the CP3. Eric Merchant did tell me that too much CP3 inlet psi could blow out the front seal of it, so be mindful? That would be a quick ticket to a crankcase full of diesel!
