while rowing thou the gears the other day i was noticing and thinking
how does one make the vanes react or respond faster to commanded changes... ?
you auto guys probably don't realy have this to worry about as you don't see the rpm swings us hand shakers do.
so i was simply thinking the vanes are essentially controlled by oil pressure. correct? engine oil pressure very on RPM and temp.. correct? this in turn affects the speed witch the vanes can move (not including the restrictions in the actuator valve.)
what if turbo oil was re-plumbed to run off a separate , external gear pump (with its own suction from the oil pan) set to keep a constant pressure lets say 60# or so
some fancy plumbing with check valves can keep the factory oil feed as back up if gear pump dies......
maybe even modding the actuator valve for little more flow.. dont know on this... haven't puled one off the turbot to know what it looks like.
any one else feeling what thinking .......... thoughts and ideas....
