Just purchased 04 LLY, but it needs help!
horsetrader
May 29, 2016
Hello guys, I recently purchased a 2004 DMax LLY at auction and "as-is". The story was it didn't run cause wife put gasoline in it... I towed it home, disconnected tank and ran fresh diesel in it, replaced fuel filter, and it fired up. I'm pretty sure it needs head gaskets because of the "hard upper hose the next morning", but before I sink a lot of $$ into it replacing those gaskets, I want to see what else is wrong.... currently it will not hold a prime, and goes into limp mode if I try to accelerate hard (fuel system limp 2k rpm max). Also heavy blue smoke at hard acceleration. I'm hooked back up to fuel tank now with fresh fuel and stenodyne additive, but some of the old fuel was still in tank.(1 or 2 gal) What could be causing the limp mode? Could the bad fuel filter head cause limp mode? would be nice to fix the fuel problem first then decide if I want to repair head gasket or sell the truck...
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
I was high bidder for a few days on a 04 gmc that had a bad trans " would throw itself out of gear when you accelerate". Was at 1200$ until last few hours than jumped to 4200$ and sold. But as far as your problem man id rebuild the filter head and get a alum bleader screw or atleast a new plastic one. Also check the WIF sensor it took me about a week to realize mine was cracked. New ones like $15 so cheap idea.
