Question: Jet hot coating?
ZeroGravity58
1,401
51
Maryland
Ive been thinking would there be any gains? Theres a place in maryland that coats just about anything. Would it be worth coating the manifolds, up pipes, pedestal, and down pipe or would i just be wasting time. I called them and they said they could coat everything for me inside and out. what you all think?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
it would have to help with underhood temps, and probably help spooling a bit , with holding more heat in the exhaust system , just dont know if the gains would justify the cost ?
ZeroGravity58
1,401
51
Maryland
im not sure...i also dont know if coating the stock up pipes would be worth it or not? i have seen gains by coating headers on gas motors. nothing huge but i saw a 10 HP gain.
The Neens
BFD
4,596
Monrovia, Ca.
Good point...What do they want to charge to coat everything?...If it's reasonable, I say do it...Usually parts will last longer and obviously look better (underhood bling)...
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
check these guys out too, their coatings are guaranteed to past 1300 degrees. not many in the country are.
Custom Concepts
Performance Coatings & Components
19330 Mt. Elliott
Detroit, MI 48234
313.369.2447
CCPerformance.com
[email protected]
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
904
31
Western MA
www.matpa.org
Custom Concepts
19330 Mt. Elliott
Detroit, MI 48234
313.369.2447
CCPerformance.com
[email protected]
X2
I had some SBC headers coated by Jet Hot in 2000 and the coating started to pit 8 months later. They were recoated for free (I paid shipping) and the recoating lasted 6 months before pitting happened again.
The funny thing is I had a new crossover pipe coated at the same time and forgot to send them one of the couplers. I realized my mistake too late so I just cleaned the coupler and painted it with high temp silver manifold paint. That coupler looked great the day I sold it, but the Jet Hot coated crossover pipe (which the coupler was attached too) looked terrible and they did not see salt/snow.
They may have changed their formula over the years, but I am very hesitant to try them again.
Just my experience though......your results may vary :D
Edit: I just looked at the pictures Kat was referring to, and I will say that there are "different" types of high temp coatings out there and many companies offer several different styles/colors. It seems the brighter, silvery, or shiny colors are less durable. The flat colors (like what the up-pipes in the pictures have) are much more durable FWIW.
I was looking for form over function and went shiny :) so that has to be considered as well.....
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I have two types of coatings on my F7 snowmobile, one's a black coating, inside and out on a y-pipe manifold done by D&D performance in NY and one is the Shiny inside and out on their single pipe and can done by Speedwerx. the black started flaking after a 6 hr ride and is now rusting, the shiny i dont think will ever lose its luster, they recommend washing it down with soapy water and not allowing chemicals to touch it which i have followed so far.
Redbone
but this one goes to 11
May 1, 2008
261
Indy, IN
Here's what I was quoted:
Turbine housing...........$185 (2450* coating, all else 1700*)
Cartridge....................$85
Up pipe.......................$55 per foot
Down tube...................$65 per foot
Ex. manifolds...............$250 each
