I'm probably going to try it out but will it raise my oil psi to high and cause damage or will I be alright. I only ask because it gets pretty cold around here sometimes
No problems with psi, holds right around 90psi (factory gauge) on cold startup @ 24*.
I have noticed it being ever so slightly harder to start due to the increased thickness over the Rotella. It would be something that I wouldn't even notice if I didn't keep watch for it. Quick cure is to bump your desired plug-in temp up 10*.
Hey E.carter, do you happen to know who makes the oil for John Deere? Just curious.
Hey dumb Question, Where can I get this oil do I have to order it or will say a tractor supply shop like a co-op carry it.P.S How can I get my oil to clean up and not be so black
so what is the weight of this oil? Does this increase oil psi do to the heavier weight?
