After a few minor little things last night we got it running, however it sounded like a nitro methane powered dragster. My hopes werent up, called it a night and this morning I pulled the codes off of it. P0089 and P0090. Both are Fuel Pressure regulator codes.
Turns out I never hooked the wires up to the dang thing. I also remembered earlier that i never hooked up my MAF, low coolant sensor and the ac sensor deal that plugs into the shiny thing by the cab. These didnt change anything though.
Fired it up and it ran perfect, minus the coolant pissing everywhere. The one leak that sprayed coolant all over the windshield hood, motor and turbo was a bad o ring on the cab heater feed line. Replaced the o ring and no more leak. The other one was a cracked weld on the cab heater return line, So I ran down to my neighbors and TIG welded the crack. So no more leaks.
Heres the video
http://www.youtube.com/watch?v=iJoBKOrJlXY
Heres the video
