Help: It ran fine before W.T.F
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
Hey everyone its been a while since I turned my programmer up. I 've been running on the first and second power levels since the summer and have had no issues. Me and a buddy were out running around shopping for new rifles when we got to talking about the truck and he was curious how it ran cranked up. So i took it to level 4 & retrained the tranz drove it for a few hrs around town and the highway and then I started gettin on it a bit and its real doggy it hesitates bad and then comes alive I dont think its turbo lag it just falls on its face and then takes off ? it also shifts different and somtimes kinda seems like a slip but ? no limp mode or antything its just running like sh#t and I dont know why. I thought maybe the more I drove the beter it would get but still the same ( @least its not worse I guess:confused: P.S , air filter is good , oil recently changed , fuel filter is @ 67% all fluids are good and I use stanadyne every other tank of fuel. I'm lost this thing is really starting to bother me:(
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
I dont know what my desired fuel psi should be? What am I looking for should it be a certain psi @ a certain rpm ? Give some suggestions as to waht it should be for the tune I'm running. What's tc ? Gonna change fuel filter this weekend.
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
No shim kit installed yet but I do have one, havent bought a lift pump yet. the truck ran fine and very well the previous times i have had it on stage 4 . I dont know what the deal is . As for the shitty shifting it very well could be the tc I didnt think about it .Tranz has never limped or had a real noticable slip but something is the matter some where on the truck cause its not runnin like it has in the past. Again I dont know what im looking for for fuel psi.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
You are looking to see that desired and actual stay fairly close to each other. If they follow each other to a certain point (25-26K) then actual falls suddenly and drastically than it is likely your FPRV. If they follow each other to a certain point (18-20K) then desired continues to rise and actual can't keep up then a lift pump would help.
