Okay, about 3 weeks ago I was driving, had been cruising in high gear for a while. Came to a stop @ a light and my truck didn't want to take off. I pulled into the next store and put it into M, the (4) was lit up. The reverse would still work. I shut the truck off, put it in gear, started to take off as if in first gear, then felt like it went into neutral, then it slammed into gear again, except it is in 4th gear. I limped to to my friends shop and he pulled the codes that both selanoids B and C were stuck. I went home and tore the transmission apart and upgraded it to the PPE stage V and a percison ML converter. Got it all back togeather today, took it for a ride, shifted up thru the gears fine. Then when I stopped and turned around it started in 1st, then same neutral feeling, then slammed into 4th again. This sems to be a unique problem after doing as much research as possible. Im wondering if it could be bad selanoids? possibly picking up some debris I missed while rebuilding? or if I should be looking for something else? Any help would be greatly appreciated, I'm starting to have truck withdrawals..........
