LB7: Is This Signs Of Pump Rub
RobsDmax
832
Arthur, Ontario
Took a look under the truck and found this. Is this pump rub or just the casting of the t-case?
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Is it soaked on the passenger side area? If not more than likely just leaking case halfs. Good time to get the pump rub fix installed before you need a rear case half.
