Question: is it possible?
VinceGU05
duramax lover downunder
May 20, 2011
164
Melbourne, Australia
to blow the oil seal out of the turbo on the exhaust side if by accident both vents on the rocker covers were blocked creating some crankcase pressure?
standard turbo etc.
13,752
822
I would say it is highly unlikely. Probably much more likely to blow out a main seal.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Or did you spin your cam bearing slightly blocking the feed hole and limiting oil to the turbo. Then once the seal is toast, the little bit of feed oil that is there is leaking???
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Would seem likely with it ruining 2 in a week. You can look down the oil hole right at the bearing.
Sent from my PC36100 using Tapatalk
VinceGU05
May 20, 2011
164
all standard turbos. first 60k miles old before the transplant into the truck... 2nd fresh reco'ed.
3rd one still going strong after 2000 miles. only discovered crankcase pressure problem shortly after the 3rd one was bolted on.
