Hey everyone, just thought I’d share my build in-progress for my first post in this group!
2006 Sierra 2500HD CCSB 4wd
4.075” LB7 block
Stock LBZ heads
Callies Compstar crank
Carillo Pro-H rods
Thermal coated 16.5:1 Mahle Race Cast pistons with .075” valve pockets
Hastings compression rings
Total seal oil control rings
Mahle Clevite H series rod and main bearings
SoCal 3388 standard fire cam
Wagler dual valve springs with steel retainers
Wagler pushrods
ATI Super Damper balancer
BD flexplate
Wagler pinned and shimmed oil pump
ARP main studs
ARP 2000 head studs
Mahle grade C headgaskets
PPE manifolds and up pipes
DHD glow plug deletes
All in all I think it will be a solid engine. Things I would do differently and/or next time around... I would probably opt for Fingers cast oval bowls without valve reliefs, ProFab manifolds/up pipes, and billet main caps.
For fuel and air it currently has a VS Racing billet S480 with an 87x82 turbine and 1.1 T4 housing, Industrial Injection 100% nozzles, and a PPE dual fueler setup with two stock LBZ pumps. I do have plans to go to 200%s after the trans re-learn is complete and I enjoy some time behind the wheel.
The truck is currently at a local shop receiving some transmission upgrades/repairs. My Goerend R converter is being refreshed and restalled to a J, they are installing a TCS billet input/output/C2 hub, Goerend P2 planetary, and swapping the Raybestos GPZ clutches in favor of Alto G3s. We believe for my intended use, power level, and weight, that the stock intermediate shaft will suffice.
I’m hoping to have a fun street truck that will run in the 10.xx @ 12x mph range @ 6700 lbs, on a street tire!
I have to thank Larry’s Engine & Marine in Tucson, Arizona for doing an amazing job balancing the rotating assembly and machining the block and heads. I’d also like to thank Copperhead Diesel in Chandler, Arizona for handling all of the transmission work!
4.075” LB7 block
Stock LBZ heads
Carillo Pro-H rods
Wagler pushrods
BD flexplate
ARP main studs
ARP 2000 head studs
