Intercooler Boot Upgrade
S Phinney
4,008
Quncy, Fl
I had a split in my drivers side silicone boot so I decided to upgrade it and hopefully eliminate that problem for good. At the track this past weekend I could only hold about 35 lbs. Since fixing the leak and increasing the pipe sizing along the way I can now hold 50lbs. Here are a few pictures.
picture.php
picture.php
picture.php
S Phinney
4,008
Quncy, Fl
where did you pick that up??
im interested in something like that.
I ordered a 90 degree aluminum bend and cut it down then welded to match the factory angles. I then used a bead roller to put the beads on. Then when I got home, I took it back off and used some Mother's polish and my polishing wheel to shine her up a little.
polaris1450
Sep 21, 2009
quebec canada
afe tube
a great improve afe intercooler pipe made from stanless steel .it is good to not taking the hottest temp under the hood.the new shape in the tube eliminate the 90 degree angle and also had a 3"
