D
Deleted member 32467
Guest
I'm torn down so can not check with my gauge..
How much vacuum (if any) is available if you tapped into the intake of these Duramax engines? I have an LBZ.
If we weld a bung into our intake horn right near the turbo will there be consistent vacuum there? Will the vacuum increase with throttle?
What about where the stock "Air filter service gauge" is in that grommet near the air filter box, would vacuum from that point be consistent with vacuum up closer to the turbo in the air horn?
Thanks for any input,
