To go along with the up-pipe for those that want to completely delete the EGR and run the bigger CAI tubes does anyone have these part numbers?
I'm not talking about a delete kit - I'm talking about stock LB7 parts. All you need to delete EGR is LB7 passenger side non-emmissions up-pipe - which the part number for is listed here. Then the LB7 intake bridge is one piece that comes all the way out to the intercooler tube and it will bolt to LLY intake runners. So you add the LB7 up-pipe, intake bridge and passenger side intercooler tube and boots and then you can completely remove the EGR valve and cooler and run a heater hose straight from the motor to the firewall. This will also make the LBZ turbo inlet fit the LLY better. Talking about doing it like this guy: Silver Bullet
The LBZ turbo inlet will fit without any mods to an LLY,
Aren't the LB7 intercooler tubes smaller on the LB7 than an LLY?
Is there a part number for this piece somewhere?Link to the Van bridge
http://208.109.104.11/forum/showthread.php?p=83313#post83313
Henry, do you buy any chance have the PN for the O ring I'll need for my LBZ air inlet tube? And any advice on a good place to purchase one
sorry for the threadjack
Do you mean the 2 orings on the front kneck that goes into the bridge.If so there around 25.00 ea and dont think you can use a regular oring.I have those numbers just have to look around for them later when I get back home.
