Thanks for the quick advice. :thumb:
Hopefully the damn thing will stay in there now. :rofl:
For the last few years I RTV the Y bridge gaskets into the bridge and then install it after it's set up
I don't ever use grease, its a pain, but if your having THAT much trouble your orings probably have expanded and I'd get new ones.
I calculated the load on that bridge, and it's a few hundred pounds of force. Area x PSI. Best guess is they wanted a seriously tight fit.
Doesn't the EGR cooler hold the part in? When you do the delete theres nothing to keep it all together?
The brackets on the delete pipe are suppost to do the job. I made two brackets on my delete pipe and it wouldn't hold it in. If you do the math as Pat suggested, the amount off force pushing out on the elbow is substantial. I had trouble with mine flexing and coming part way out.. that wasn't the end of the world but the constant moving everytime it saw pressure eventually wrecked the o-rings.... Building that piece I showed above stopped it from moving at all... key to both sealing and o-ring life. I don't know that all delete pipes suffer from this problem like mine, but I would be willing to bet there is enough movement to eventually kill the o-rings....
