Will it make a mess doing in my driveway when I open the trans lines to replace the cooler? Getting board, might kill a couple hours right now instead of hitting the shop.
You will need a drip pan underneath. You will probably loose about a 1/4 quart of fluid or less. If it takes you a couple of hours you're messing off cause it's a 25 minute job at best.
Done, simple as piss.
Took time to repair broken grill clip
Only lost about 1/16 quart if that.
Anyone want a stock cooler? Good shape, works like the factory designed it.
