Going to install new autometer boost gauge. Were is the best place to plumb it in. Can I use the rubber hose between turbo and waste gate next to the PPE blue thing.
I prefer to have the boost gauge hooked in as close to the engine as possible. The aluminum elbow that the cold side CAC tube connects to is a good place to drill and tap.
theres a thread on here somwhere not sure where but he deleted the intake heater cut the probe and spring off and tapped the bung for the gauge...sounds like it would work and be cheap
you can put it there, but its best to have it on the other side of the intercooler, the 2 readings will be a little different. the one on the engine side of the intercooler will tell you how much is actually going into the motor.
