want to put a autometer cobalt 5 inch tach in my puller so I can pay attention or atleast try to going down the track what would I need to install the tach? can I tap into the factory tach wire? thanks
You need to put a resister on tach feed with a 12 volt supply to steps it down to 5 volts. Just going to the tach wire won't make it work.
Theres plenty of articles out there describing how to hook up a tach to an LS engine, and the DURAMAX outputs the same signal from the ECM as an LS does.
The DURAMAX ECM could actually power most any electronic GM speedo. I run my 95's speedo right off the ECM, and use the the 128,000 PPM signal for my ABS. The speedo in my 95 will work with the signal from most any DRAC or VSSB from 88-99 including the black box ECM's from 96-00. My tach was a different story. Since mine was a diesel from the factory, it used an alternator driven tach. Si got a different alternator plug and hooked in there for mine.Yep!! Exactly right.
Dmax ECM outputs same VSS/speedometer signals as any 99+ gasser ECM too.
