I've been trying to find someone to install an EGR blocker plate and turbo back exhaust near Pomona, Ca with not much luck. Anyone know someone competent and willing to do the work for a reasonable price?? Thanks in advance!!
I haven't purchased the exhaust yet because I was waiting to find out a place to get it installed. I live in a condo that doesn't allow working on cars and I really don't have the time anymore to work on anything regardless. I am thinking of running an MBRP 4" turbo back exhaust (or something comparable to that) and would like to dump the exhaust under the truck. The EGR plate concerns me a lot more though because I have read and heard that it is a pain to install...
As long as it's an "off-road only" vehicle, you should be able to find some help...
Maybe I should install it for you .
Im no shop , just a driveway diesel junkie with alot of tools .
If everything is there to install complete and it doesnt need to go on a lift , all should go smooth . Is it lifted or stock height ? I have a welder to spot some connections or to keep tailpipe from twisting over hard bumps . Done that for a few that like to twist on connection over axle . And spotting the tip so nobody snakes it .
Havnt done one with DPF , but how hard can it be . Done earlier models .
I have many friends that have done it , so advise would be there if stuck . Dont think that is needed though . Should be a no brainer . Just a pain to get out on the ground .
Once you get all that crap out of the way the rest is easy . Well kinda , the downpipe is always a bitch . Getting to the bolts and clamp . Its tight up there by firewall .
Im in Santa Ana . 5/55 frwys . You work weekends ? Whats your schedule ?
The blocker I have done many , it is just a pain to get bolts loose . I know of a few that have snapped the bolt trying to loosen . Trick is to use penetrant and go from driverside and pull towards you . The right short wrench too . And watch the knuckles .
10 minutes for that if it goes smooth , 20 if it is being a pain .
I will probably be the most reasonable in the $$ department also .
Johnny
alligator performance has the best package deals. Call him first you can get everything at one time.
