installed shift valves... spare parts
csbsixsix
Mar 27, 2014
14
Wyo
Just finished installing Transgo A1-SHIFT VALVES and a Sonnax e shift valve spring. Ended up with an extra spring that I can't figure out for the life of me where I left it out of.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
396
Looks like a trim spring on A or B, I can't remember which has the spring.
csbsixsix
Mar 27, 2014
14
Wyo
this one is quite a bit smaller in diameter. I did get the outer spring on A trim. I guess I could have been a bit more exact, I went through the instructions on the Transgo kit, the Sonnax tool and spring, and my Transgo Jr. kit. Every spring in all those illustrations are in their spots. I'm relatively certain I pulled something out I didn't need to, just cant figure out what. Other than this one I have all the replaced valves and one replaced spring accounted for.
csbsixsix
Mar 27, 2014
14
Wyo
image.jpgTransgo Jr sk has been in since around 2012. Did the install in Colorado. Tossed the stock parts, unless I found a way to accidentally end up with a factory spring in with the Transgo spring. Mystery spring is slightly longer and narrower but it seems like it'd work just fine as a trim valve spring.
