Installed my Aerofoce Scan gauge
kodiak
Sep 25, 2007
178
My Kodiak did not come with a transmission temp gauge. It was a option.:rolleyes:
So...I decided to buy the Aeroforce Scan Gauge.
It has tons of different parameters that can be displayed 2 at a time.
Reads and Clears DTC.
Fits into any normal sized gauge hole for a 2" gauge....then just plugs into the OBD II. Thats it, no power wiring, no ground wiring. Just a plug it in and go.
It will read turbo vane position, pulse width, intake air temp, coolant temp, trans temp, trans slip, oil temp, oil pressure, MPG, RPM, voltage, HP and torque....and a bunch of others I can't think of off the top of my head.
The display can be bought with blue, red, green, black, white. As well as bezel color and face color.
They also come with LED lights that can be programmed as shift or warning lights.
Pretty cool gauge for the money if you ask me.
kodiak
Sep 25, 2007
178
Very cool! I like the programmable title splash screen! Does it also hook up to your computer to set that, change parameters etc or ??
They run about $200 correct?
Thanks...they actually are programmable by using the buttons on the face of the gauge. Lots of parameters to choose from. And they are right around $200 depending on where you buy them from. Email Todd at this address, and tell him the Kodiak guy sent ya. Who knows..you might get a heck of a deal. [email protected]
