last week(6/4) truck through a P0752 code... shift solenoid valve stuck on. and i lost 2nd gear. truck would wind 1st out to 3200-3500rpm then shift to 3rd and lockup. TCC is tuned to come on by 30mph in 2nd, 3rd, and 4th.. manual 2nd gear was barely there. down shit out of 3rd it went straight to 1st..
replaced both solenoids and a VB from a working 4l85 problem still existed..
so i pulled the tranny.
found the stock 16 element sprag rotated freely in both directions. found both forward clutch, direct clutch and drum manual 2nd gear band, forward clutch hub, severely discolored. there are bushing on both sides of the forward clutch hub, both where gone when i pulled it a part.
i curently have 195k on the chassis and 110k of that is between 14-26,000lb at an estimated 300fwhp
i replaced FC, DC, DC drum, intermediate sprag with a 34 element, FC and DC pistons, 2nd man band with a 1.255" wide band(stock is 1") forward clutch hub with a fordge unit, seals and bearing thorough out the tranny. also replaced the roller clutch for the over drive unit due to me breaking it after i inspected the clutcehs and steels.. both 4th gear clutches are brown with no burn marks and the steels are shinny with no hot spots.
aamco gave me B&W kevalat clutched with kelone steels with slots in them...
so pictures
the hacked harness from the PO when i swaped both solenoids
forward clutch pack on the left direct clutch drum center, intermediat clutch pack top center, forward clutch hub bottom center, direct clutch pack right on of the 4th gear clutch pack top left corner
old/new forward clutch hub
alto steels for FC and DC packs
34 sprag unit on the left stock 16 sprag unit on the right
the roller clutch i broke
whole thing before i tore it apart.
old style DC piston cast aluminum molded steel new style piston with return springs for each
so pictures
