Injectors
pelican
Nov 7, 2012
3
Magnolia Springs, AL
Just found this forum while trying to established a price. I have an '04 GMC 2500 4x4 with 202K mile. It smokes quite a bit at idle. Mechanic told me it needs injectors and would cost about 1800 bucks to replace with OEM. Does this all sound about right? First diesel I have owned other than a backhoe so not real familiar with repair cost on them.
Thanks for any help, Pelican
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Yes. 01-04.5 are known for injector issues. That's dirt cheap for them to replace them. Cheapest I found oem Injectors for is 1750. That's with out labor.
6,022
i would be leary of what ever injector he is putting i there for that much. thats too good to be true if labor is included for all 8
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Yes. 01-04 are known for injector issues. That's dirt cheap for them to replace them. Cheapest I found oem Injectors for is 1750. That's with out labor.
Fixed it for you LLY's don't have the LB7 injector issues :thumb:
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Make sure you get genuine Bosch remans! Lotta junk floating around.
This isn't a cheap procedure, do yourself a favor and buy quality injectors so you're not going through this mess again for a long while:thumb:
Get what you pay for people!!!!
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
2500-3000 for all necessary parts and OEM injectors is the great to good price range, Get references for a goood duramax tech in your area.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
1800 would cover labor +tax, and labor only, at a reputable diesel shop, for an lb7.
Injectors typically cost 260-300 ea for bosch replacements, x8 your lookin @ 2400-
Lb7's typically run 4400 around my area, out the door.
Remember, you get what you pay for, and injectors are possibly one of the most important parts of the truck, not to mention one of the most expensive.
duramax hd
664
CT
Does anyone know for sure if you are getting bosch remans from the dealer when you purchase remans through them? I've gotten some conlicting answers.
