earlier this spring i had some head gaskets issues, pulled motor had head gaskets redone and put headstuds on. been running great since then. about a month ago i noticed a white haze every now and then, but it has been getting worse week by week. it haze's instantly when its idleing, and sometimes has a rough idle but not all the time. coolant level has not changed and there has been no low coolant light. tested the balance rates yesterday and they are all within + - 2 so those 'should' be ok? oil level was a little bit low last week when i checked it (has about 4000 miles on it) so i added a little to it. seems like it has a strong fuel smell under the hood, but cannot smell any fuel in the oil when i checked it. also fuel mileage has not been affected i am still getting my usually 15 or so.
any ideas on what is causing the bad haze im lost? do i have some ring issues or could my injectors still be bad even tho the rates check good..
thanks
thanks
