LLY: Injectors... Noooo!!!
Jonesin33
Aug 26, 2011
189
TX
Well got a call back from the dealership and I have 2 injectors leaking... $1400!!!
Does that sound like a legit price. With two already being replaced, should I go ahead and do all 4 on that side?
Sent from my DROID RAZR HD using Tapatalk 2
Jonesin33
Aug 26, 2011
189
TX
And being an LLY with only 100k miles, why are two out already?
bluecollar
351
ia
I do all 8 with injectors from gm for 2800 on a lly which might be to cheap lol but only done a few buddies lly so they wanted friend price lol... which ones are bad.. there not that hard to change, i would try to find somewhere to take it besides the dealership
Jonesin33
Aug 26, 2011
189
TX
They said #2 was Soping up and #3 is leaking fuel
bluecollar
351
ia
Well neither of them are the worst to get to.. do you not feel comfortable swapping them urself? As u have 600$ for the 2 injectors so there getting 800 for labor which is nuts in my book to change 2 lly injectors
paint94979
Beer Nazi
Sep 18, 2006
11,715
Do not pay 1400$ for that... You can buy all parts needed for under 700$ and do it yourself in a few hours
Aaron@LDS
Goin' Broke!
95
Saint Johnsville, NY
That's a high price for injectors that are outside the valve covers (unlike our LB7's)... What's your symptoms? Are YOU convinced you have bad injectors?
Dealerships read codes and throw parts at these trucks. Not many actually diagnose anymore...
Jonesin33
Aug 26, 2011
189
TX
Had the truck picked up and it's going to Relentless Diesel
Jonesin33
Aug 26, 2011
189
TX
Symptoms are knocking noise at between 1500-2000 rpm... Runs fine, not throwing any codes, no smoke... Idle sounds good... Only way to hear it is put it in gear and get the rpms between that range. At least I don't hear anything at any other time. Aside from the sound, would never know anything was wrong.
Aaron@LDS
Goin' Broke!
95
Do you use additives? They may be right and it does sound like a fuel knock, but sometimes it needs a good cleaning. It could also be the tuning. With some wear your injectors may be making more noise, and the EDGE may amplify the cause of the knock at those RPM's.
I personally would take their advice for what it is... advice... And I would try doing the DIY injector cleaning procedure. Along with keeping an eye on my balance rates. I would also try going back to stock tuning to see if the noise is still there without tuning adjustments. You will need to disconnect the EDGE from the bail connectors under the hood to return it to stock.
Thats what I would do first, before just throwing parts at it.
Jonesin33
Aug 26, 2011
189
TX
Sorry I need to update my signature on here...
No longer have Edge, now have EFI Live from ATP and I just put nearly a whole bottle of Diesel Kleen in it... I was hoping a good cleaning would do the trick
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Diesel kleen in the tank isn't going to do alot to clean sticking injectors. get teh GM upper engine cleaner, mix it with 2 gallons of diesel, and run it through just the engine(disconnect the 2 fuel lines at the rear of the engine and hook the can of cleaner mix straight to the engine). It will take an hour or so to run it all through, but it is about the best way to clean them short of pulling them out and ultrasonic cleaning them. And I know GM wants a little over $400 per injector if your paying full list price. I found Lincoln diesel had the best price for LLY injectors if you buy all 8.
Jonesin33
Aug 26, 2011
189
TX
Thanks for the information bud
Jonesin33
Aug 26, 2011
189
TX
Truck is back on the road. Hell yes! Thanks to Relentless Diesel for the food work. Ended up needing one injector, while it was there went ahead and had them put my egr blocker plate in (which I'm convinced made the Turbo scream) all said and done... They cut my bill from the dealership in half, score!
